Problem with the radiators and sensors
Dark
Unread post by Dark »
I'm having a problem with the front right radar and sensors, and the cruise control isn't working.
I have these codes, and when I delete them, they reappear. How can I begin the repair?
Peygout 3009 model 2019 GTL
UF100
B1225
B1226
B1251
B1245
B1210
x 8122
Re: Problem with the radiators and sensors
To get sensible answers you should add your engine and gearbox types for reference :)
PaulC5
x 686
Unread post by PaulC5 »
I have not bothered looking up what the definitions are for all those codes, perhaps if you can provide them it will help others to help you. The one I searched on B1225 came up with this topic but did not finish with a solution viewtopic.php?t=83333
Another topic I found on B1251 found the front right 2 sensors had been connected up by mistake to each other and swapping the connectors back solved it. Have you been doing anything to the wiring, has there been damage to the front bumper ?
Have you tried a Peugeot dealer to get it fixed ?
Dark
PaulC5 wrote: 05 Apr 2026, 20:09 I have not bothered looking up what the definitions are for all those codes, perhaps if you can provide them it will help others to help you. The one I searched on B1225 came up with this topic but did not finish with a solution viewtopic.php?t=83333
Yes, I saw this post. No, I didn't go to the car dealership. Yes, there was an accident in the front collision.
