Setting mirror reverse angles DS7
Dagman
Unread post by Dagman »
Hi all, how do I go about setting the door mirror reverse tilt angles? It is a DS7 crossback 2021, it does tilt them in reverse but not enough. Is there a way to set them? I've tried selecting reverse, set the mirrors to where I want, press my seat memory to save but it doesn't do the usual sound of confirmation. The mirrors still don't tilt enough going back to original reverse tilt angle when I select reverse. The manual doesn't appear to cover this. Any ideas appreciated.
x 8123
Re: Setting mirror reverse angles DS7
You may get some idea from here, I haven't read it: https://dsforums.net/t/ds7-opera-tilt-s ... verse/1535 :)
Dagman
Hi mickthemaverick, suggestions in that post were a battery change which presented further problems. All other things on my ds7 work fine apart from the start stop not operating (not too bothered about that) and getting it to remember the reverse mirrors tilt down position. Thanks for the info, still if any other ideas are out there that would be great.
