2008 Peugeot boxer mk3 2.2 starts and drives but scanner can't communicate with the engine ecu
Timothy+++
New User
Unread post by Timothy+++ »
Hello I'm stuck with my Peugeot boxer it starts and drives I can communicate with all modules except I can't connect to the engine ecu with a scan tool I have tried multiple professional scan tools checked fuses etc I get a code 01701 in the abs module and I also had a code u1601 (can bus off) I'm stuck with it now any help would be greatly appreciated
x 8166
Re: 2008 Peugeot boxer mk3 2.2 starts and drives but scanner can't communicate with the engine ecu
Have you checked all the plug connections to the fuseboxes and ECUs? :)
