2.0HDI no response on throttle
Alexelax
Unread post by Alexelax »
Hi everyone
I have a 2.0ehdi that got the timing belt replaced. Locked with pins
Now the car starts directly but no response on throttle and dies after a few second. No fuel lines where disconnected. Timing synk on OBD say OKEJ and no fault codes.
Timing locked on bigger hole on cam and crank was locked on lower pin
2.0eHDI automatic
x 8119
Re: 2.0HDI no response on throttle
If it starts and runs correctly for a few moments, that is a sign of immobiliser intervention. Since this appears to be a fairly new model being the 'e' I cannot be of any help other than to suggest you do a BSI reset following the procedure in the link below and see if that makes any difference? :)
viewtopic.php?p=601679#p601679
