Citroen C4 grand picasso! Gearbox oil!
ProfessorPike
Unread post by ProfessorPike »
Gearbox issues, jerky, noisy!
MOT flagged up an oil leak and there is a LOT around the gearbox. So I thought a top up!
Watched this video, and thought, easy enough
Unfortunately, I think this must be for a newer model, my car looks nothing like that, in terms of where the filler plug is.
Its a 2007 1.6Hdi semi automatic. Can someone enlighten me as to where i find the filler plug please?
x 8122
Re: Citroen C4 grand picasso! Gearbox oil!
Hopefully this will help you out: :)
Piloted gearbox oil change.pdf
Copied from Service Box
(230.27 KiB) Downloaded 51 times
ProfessorPike
That is amazing, thank you!
I do keep (also) getting results for EGS actuator fluid, does this apply to my MK1? Results keep suggesting it. I do get an error when i start and there is an awful noise when driving, not idleing.
