Hi all,
I have a 2015 Citroën C4 1.6 HDi semi-automatic. I am changing the clutch and have now noticed that the layshaft bearing is damaged. Would someone be able to tell me the following:
1. What is the size of the bearing?
2. Is it possible to change it without stripping the gearbox?
Thanks in advance!
Rod
Citroen C4 Semi Auto layshaft bearing issue.
- x 8137
Re: Citroen C4 Semi Auto layshaft bearing issue.
Unfortunately the parts data available to me is only for pre 2013 vehicles so I cannot help, but there are members with better data access and hopefully one of them will see your post and help out. Good luck
