Citroen Nemo Rear Door Fault
WeeNemo
Unread post by WeeNemo »
Hi everyone, having an issue with the rear door of my 2009 citroen nemo van, and I thought it's probably about time I come on here and ask the experts!
Basically I've got a BSI that won't go to sleep and drains the battery in 2 days of no use, using a Thinkcar diagnostic scanner I found in live data that the rear door is showing as open when closed, and closed when open.
I've fitted a 2nd hand door latch from a 2013 nemo from a breakers, but it's not made a difference.
Has anyone experienced this before, or does this indicate broken wiring?
Thanks :-D
x 8042
Re: Citroen Nemo Rear Door Fault
Does the rear door switch have 2 or 3 contacts? :)
WeeNemo
mickthemaverick wrote: 21 Mar 2026, 14:38 Does the rear door switch have 2 or 3 contacts? :)
Hi mate, thanks for the reply. What do you mean by 2 or 3 contacts sorry?
x 8042
The terminals that wires connect to, 2 or 3?
WeeNemo
Ohh yes sorry its 2 contacts
Thanks mate
x 8042
Then it s not miswired. Have you done a BSI reset?
WeeNemo
mickthemaverick wrote: 22 Mar 2026, 15:00 Then it s not miswired. Have you done a BSI reset?
Ahh OK mate thank you, I haven't done a reset no, just the battery going flat a few times, bring it in to charge, connect again and start her up. Would this be the correct reset procedure :
Step-by-Step BSI Reset Procedure:
Prepare: Lower the driver's window, turn off all equipment (stereo, lights), ensure doors are closed, and remove the key.
Wait: Open the bonnet and wait 3 minutes for the BSI to go to sleep.
Disconnect: Disconnect the vehicle battery.
Wait: Wait 15 seconds.
Reconnect: Reconnect the battery, wait 10 seconds (do not open doors).
Wake up: Through the open driver's window, switch on the sidelights.
Ignition: Turn on the ignition and check system functionality.
Key Sync: Hold the lock button on the key for 10 seconds.
Final Test: Start the engine, check for errors, and test locking systems
From Google
Thanks, very much appreciated
x 8042
It looks right but this is the one the forum uses originally direct from PSA: :)
viewtopic.php?p=601679#p601679
WeeNemo
mickthemaverick wrote: 22 Mar 2026, 15:16 It looks right but this is the one the forum uses originally direct from PSA: :)
Fantastic!! Thanks so much
Right I just went out to check... And I've no idea why I thought it was 2 contacts, the connector on my rear door latch has 6 pins in it, 6 wires going into it. It's an 8 pin connector, 2 are blank
Apologises!
x 8042
Aah, well that complicates things. Do the reset and then see if it is still working back to front. :)
WeeNemo
mickthemaverick wrote: 22 Mar 2026, 15:34 Aah, well that complicates things. Do the reset and then see if it is still working back to front. :)
That's definitely my luck :lol:
Will do mate, I'll post back shortly
Thank you
x 8042
This is as close as I have for your door locking diagram. If you read it in conjunction with the guide at:
viewtopic.php?p=782862#p782862
you may be able to sort it out. Good luck
Nemo locking.pdf
Copied from Servicebox backup
(2.62 MiB) Downloaded 29 times
