XM MK2 lexia Comms issue....
jaisunny
Unread post by jaisunny »
Got a 98 xm that has the 30pin connector.
I've got some Comms issues, it only detects abs and suspension in lexia.
Any ideas what could be the issue?
x 1481
Re: XM MK2 lexia Comms issue....
Unread post by xantia_v6 »
I assume that you have a Chinese clone Lexia 3 and a 16 to 30 pin adapter. Those adapters are often wired wrongly and won't talk to all the ECUs.
See viewtopic.php?t=49045 for more information.
jaisunny
Correct,
Even if 2 or 3 ecus are picked up? It can still be rewired wrong?
x 1481
On the XM and Xantia with 30 pin diagnostic connector, each ECU is connected to a different pin on the 30 pin connector and the Lexia switches between them, so you can lose some ECUs while other work correctly.
It is also possible that the Lexia adapter is partially faulty. Ideally you would find someone with a working 30 pin setup so that you could narrow down the problem. Which region are you in?
