Airbag warning light Xsara (what else?)
funkster
Unread post by funkster »
Which connector under the seat is the culprit? There's a green, brown and yellow one under each seat, and a big black one under the driver's seat. Or can it be any one of them??
Do they all control the airbag?
Thanks for your help.
x 1056
Unread post by wheeler »
the brown ones are the seatbelt pre-tensioners,the green ones are for the lateral airbags in the seats.replace all of the connections at the same time,you will end up having to do them all anyway.
funkster
And the yellow??
It's the side airbag that lights up, so I guess it's the green ones.
x 1056
i think the yellow is for the warning lamp if you forget to put your seatbelt on.
