Hi. Have a picasso VF7**************[VIN obfuscated, can be read by forum staff]
It won't select gears, tries when lever moved for a second, clicks on the gearbox but it won't select.
The only fault is U1310-96 I disconnected the plug in the top of the gearbox and there is 12v on the big terminals to it, no rusty connections. Fault permanent won't clear. If I select manually (moving the lever on the gearbox)it shows correct on the screen.
Maybe the selector ? Is that on the top of the gearbox the gearbox ECU or just the selector? Any ideas of where to run?
C4 picasso gearbox not working
- x 8144
Re: C4 picasso gearbox not working
There are a fair number of videos on Youtube about this car and its semi auto box, have a look through and you may find your solution.
Wawpeyo
Do you have any links? Been looking around and haven't seen any videos about this, which really seemed strange
- x 8144
Just an example:
Wawpeyo
Well yes, have seen that one, however no, not applicable to this one
- x 1496
The code suggests no comms with Gearbox ECU - is it talking on the network when you scan it? You appear to have power at the connector - is the earth good?
Wawpeyo
Seems like talking to it, the earth is good and when you request to set the neutral it says completed. Replaced the gear lever just in case, next will have to replace the actuator (believe that's the ECU)
Wawpeyo
Well , replaced the actuator and the fault changed to intermittent, cleared and attempted relearning but no luck, seems like is looking near to scrap, not sure what else I can do and for sure dropping it in a garage will come back with a new gearbox and maybe still not working
Wawpeyo
Tried to set positions for the lever and it says actuator blocked, any last option ideas?RichardW wrote: 12 Mar 2026, 07:26 The code suggests no comms with Gearbox ECU - is it talking on the network when you scan it? You appear to have power at the connector - is the earth good?
Wawpeyo
It makes some noises so the actuator is trying to move but it won't, if I move the lever on the gearbox it shows the right gear but still won't work, might will be the actual gearbox in the end
Wawpeyo
Any ideas someone?
