Nemo with 0.5a draw
ohspecial1
Nemo with 0.5a draw
Unread post by ohspecial1 »
Hi Folks
Wonder if you can help
Nemo battery flat again
So went checking
0.51a draw
Now lots talk about bluetooth module looked under the seat and cannot see it
2010 nemo
x 8141
Re: Nemo with 0.5a draw
what year and model Nemo is it? :)
ohspecial1
Hi
All i can say is a nemo 2010 with seats lol
LG10 DLF
x 8141
As you mention 0.5A draw I assume you have a multimeter. So connect the mutimeter on current and put it in series with the negative terminal so it shows the 0.5A draw. Then remove the fuses in both fuse boxes one at a time until you discover which one disconnects the current. Then you know which circuit to investigate. Good luck :)
PaulC5
x 697
Unread post by PaulC5 »
0.5 amp drain with the car shut down is about 10 to 20 times what I would think is normal. Have you got a dash cam or other accessory plugged in ?
ohspecial1
By removing
F36 10 A Audio equipment - mobile telephone pre-equipment - air conditioning
Has now dropped to 0.26
x 8141
Then I'd leave that fuse out and keep going through the rest, 0.26A is still too high. You may find a second fuse which provides a separate supply to the head unit. :)
ohspecial1
Hi
Spoke to garage today and asked about it was informed anything under 0.3a is fine
Any idea where else to look
PaulC5
x 697
Does the car have an alarm ? If the back up battery in the siren has failed that might be a cause of the main battery to go flat.
x 1055
Unread post by wheeler »
ohspecial1 wrote: 10 Mar 2026, 14:45 Hi
Thats way too high, should be more like 0.05a
Is there any non original electrical accessories fitted to the van?
ohspecial1
PaulC5 wrote: 11 Mar 2026, 21:22 Does the car have an alarm ? If the back up battery in the siren has failed that might be a cause of the main battery to go flat.
Hi only central locking
ohspecial1
wheeler wrote: 11 Mar 2026, 21:54
Hi aftermarket radio unit but has always been there and now with fuse removed no longer works
