C5 X7 Steering Pipe O rings
bishopwatusi
Unread post by bishopwatusi »
Hi, does anyone know where I can get hold of some O rings for the steering rack hoses as about to swap out steering rack and don't wish to use old seals..
Many thanks,
Pete
electronmirror
x 30
Re: C5 X7 Steering Pipe O rings
Unread post by electronmirror »
Have a look at Bearing Boys (bearingboys.co.uk) they stock all manner of O rings in Viton and Nitrile rubber types. They are online and offer a quick service
Best of luck with the steering rack change especially the big bolts securing the rack. On mine they were very badly rusted in place, fortunately I opted to let my local independent Citroen garage do the work using a reconditioned rack from SSL in Doncaster
Ted
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
bishopwatusi
Thanks Ted, everything on the subframe is nicely lubed as the rack has been leaking for so long!
I collected a recon rack from SSL at Wakefield last week. Doing clutch/DMF and control arms at same time.
Think I might be sorted with seals from PatMat in Czecho..
Pete
Sloppysod
x 396
Unread post by Sloppysod »
Becarefull removing the pipes, they are soft, i changed my rack 3 times, two dodgey racks! So i got a fair bit of practice, have a look here, for my modification.
viewtopic.php?t=58498&hilit=Steering+rack
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
