Correct clutch kit for C3 1.6 diesel 2010
jeepee17
New User
Unread post by jeepee17 »
Hi, good evening. I want to change the clutch in a Citroen C3 1.6 diesel 92 HP Kilowatts 68 kW from 2010 VF7**************[VIN obfuscated, can be read by forum staff]
I want to change the clutch kit, When I look for the part online, it seems there are different diameters and also some kits are for dual flywheel and there also seems to be a difference in manual gearboxes and electronically controlled manual gearboxes. It is not clear what kit to get and i would like to have it when I take out the gearbox. Can someone give me a pointer ? Thank you very much.
x 1056
Re: Correct clutch kit for C3 1.6 diesel 2010
Unread post by wheeler »
Not sure on size but the OEM part number was 2052Z0 which then updated to 1611273080.
This may help you cross reference.
