Peugeot 508 RXH Hybrid4 2012
I had a leaking valve cover gasket which was spitting oil on the firewall side (car's right hand side). Changed the gasket without fully removing the cover as it has hard to reach rubber pipes at the firewall side. No more oil spitting but my fuel consumption is now 8.0+l/100km and have faint smoke from the injector ports section which gets a film of of oil after some driving. Not soaked but annoying. Injectors copper seals have been replaced.
I am trying to find out does this cover contain any PCV valve that would warrant a replacement, possibly whole cover (hope not)? I am looking into dismantling this again but wondering if anyone has done this before and have some suggestions.
0248T2 – Valve Cover
Thank you,
Imp
DW10CTED4 Valve cover
- x 8100
Re: DW10CTED4 Valve cover
Try a search for "Peugeot 508 RXH Hybrid4 2012 PSV valve" on Autodoc site and see if they offer a spare.
impaelas
- x 3
I'm looking for answer regarding PCV valve which I can't find online. Solenoids are attached in the back and if there's no physical damage to the cover I'd rather not waste 400€+ on a new cover. Provided there is no PCV membrane or anything similar.
