Hello, can I find out what extras my car came with when it left the factory?
VR3**************[VIN obfuscated, can be read by forum staff]
Hello, is it possible to check the VIN number?
emirock
- x 8107
Re: Hello, is it possible to check the VIN number?
Unfortunately we do not have access to the Stellantis database at the moment but hopefully one of the members with their own access will see your post and help you out.
- x 1056
Here you go
Vehicle characteristics
Vehicle family 308 (P5)
AS/RP N° 16732 88 1 0399
Warranty Start Date 26/09/2022
Engine serial number 10 Q4EL 0046482
BER e2*2007/46*0628*20
P4A 9842082399
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 308 (P5)
SILHOUETTE 5-DOOR ESTATE
TRIM LEVEL HIGH LOW
ENGINE DV5RC/UE63 1.5 L DIESEL
TRANSMISSION STT TYPE 6-SPEED MANUAL GEARBOX
PAINT TYPE STANDARD FLAT EXT TRIM TYPE
BODY COLOUR BANQUISE WHITE PAINT
INTERIOR TRIM TYPE FABRIC LEVEL 2 "D8"
UPHOLSTERY COLOUR "FX"
GEARBOX (CHARACTERISTICS) ML6CO
CONVERSION GUIDANCE WITHOUT CONVERSION
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) DV TYPE ENGINE
PRE-EQUIPMENT FOR CONVERSION WITHOUT PRE-EQUIPMENT FOR CONVERSION
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE WITHOUT BADGE
TRIM LEVEL HIGH LOW
Fuel supply-Engine
DRIVE BATTERY WITHOUT TRACTION BATTERY
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 6.3 ENGINE EMISSION CONTROL
FUEL PIPE FIXINGS STANDARD FUEL PIPE FIXING
SPEED SENSOR SIGNAL FRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY 1500 CM3
CATALYTIC CONVERTER CATALYTIC CONVERTER BELOW 50PPM
FUEL TANK NON-PRESSURISED FUEL TANK WITH LOCATING TAB
FUEL TANK INSULATION WITHOUT FUEL TANK INSULATION
COOLING MOTOR RADIATOR 28DM2 EP: 18 BRAZED ALU
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) ENGINE POWER 96KW - 300NM
SPECIAL POWER TRAIN SOUND WITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
DEVICE (ANTIPOLLUTION) EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTION EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN ONE 2-SPEED FAN 140 W DYNAMIC AIR SHUTTER RB45
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START STOP AND START STARTER MOTOR
Gearbox Transmission
FINAL DRIVE RATIO FINAL DRIVE RATIO 17 X 67
WHEEL STYLE 16-INCH LADE WHEEL
CLUTCH HYDRAULIC CLUTCH
SEAL, WHEEL END WHEEL-SIDE SEAL RZ17.5 D26
SEAL, DIFFERENTIAL END AXLE-SIDE SEAL JB2T D26
RIM/TYRE SIZE 16 INCH TYRE FITMENT
TYRE (SIZE, TYPE) 205/55 R16 94V 3PMSF REINFORCED TYRE
DRIVING WHEELS 2 DRIVEN WHEELS
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
GEARBOX TYPE ML6C
Suspension-Steering-Brakes
BRAKING ASSISTANCE IN REVERSE GEAR WITHOUT REVERSE GEAR BRAKING ASSISTANCE
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR STIFFNESS 25000 NM/RAD
STEERING COLUMN RETRACTABLE STEERING COLUMN
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR THICKNESS 27500 NM/RAD
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
SUSPENSION NORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT BOSCH 9.3 ESP
STEERING (OPERATION) LOW POWER SINGLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) SIMPLE STANDARD PEDAL BRACKET
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORNS-HARMONY
PAYLOAD NORMAL PAYLOAD
SIDE MOULDINGS (DIMENSION) WITHOUT BODY SILL PROTECTORS
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL TRIM
UNDERBODY SHIELD FRONT RIGHT AND FRONT LEFT UNDER-FLOOR LONG DEFLECTOR PROTECTION
REVERSING LAMPS WITH TWO REVERSING LIGHTS
INDICATORS MAINSTREAM LIGHT SIGNATURE
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRIC FOLDING EXTERIOR MIRROR+DIODE
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING SOUNDPROOFING ENGINE SIDE BULKHEAD+LOWER+RIGHT
WINDSCREEN GLASS (TYPE) STANDARD WINDSCREEN GLASS
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COLOUR BUMPER + BLACK BEAD + BLACK AIR INLET GRILLE
NUMBER PLATE WITHOUT LICENCE PLATE
LUGGAGE RACK WITHOUT ROOF BARS
PANORAMIC VISUAL AID WITHOUT PANORAMIC VISUAL AID
SPARE WHEEL WITHOUT SPARE WHEEL
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) WITHOUT EXTERIOR MIRROR SPECIAL FEATURE
SUN ROOF WITHOUT SUN ROOF
GLASS (APPEARANCE) WINDOW TINTED
HANDS FREE ACCESS AND STARTING HANDS-FREE STARTING
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
FRONT HEAD RESTRAINT FRONT HEADREST ADJUSTABLE
REAR SEAT MONOCHROME REAR SEAT FX+40/20/40 SEAT BACK WITH BOOT UNLOCKING
BLIND SPOT DETECTION WITHOUT BLIND SPOT MONITORING
REAR SEAT ARMREST WITHOUT RR SEAT ARMREST
INTERIOR ALARM WITHOUT ALARM FORGET LIGHTS
RADIO TELEPHONE 2 SMARTPHONES
LUGGAGE COVER SCREEN
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
AIR CONDITIONING WITH HEATER MATRIX+ADDITIONAL OUTLET
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GEAR SELECTOR FLOOR GEAR CONTROL
GRAB HANDLES FRONT + REAR + RETRACTABLE HANDLES
CONSOLE GLOSS BLACK DEC+AIR DUCT
DRIVING POSITION LEFT-HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
MIRROR LINK WITH MIRROR LINK
LOAD SPACE LIGHTING GLOVEBOX+LED FRONT CONSOLE
BOOT AND LOAD SPACE LIGHTING LOAD VOLUME + BOOT LIGHTING AUTO CONTROL
DASHBOARD EQUIPMENT "SOFT" PAINT EFFECT DASHBOARD EQUIPMENT
INT. TRIM AND EQUIPMENT VARIATION STANDARD INTERIOR EQUIPMENT DRESSING
LOAD SPACE TRIM CARPET BOOT MAT+BLACK RING
INSTRUMENT PANEL (CHARACTERISTICS) 10-INCH TFT DIGITAL DISPLAY INSTRUMENT PANEL
CHILD SEAT ANCHORING POINTS 2 REAR ISOFIX MOUNTINGS + 2 REAR TOP TETHERS
LOUDSPEAKER MOUNTING 2 FRONT LOUDSPEAKERS + 2 FRONT TWEETERS
PROTECTIVE COVER WITHOUT PROTECTIVE BATTERY COVER
POLLEN FILTER WITH+ACTIVATED CHARCOAL+FINE PARTICLE FILTER+GAS
LANE KEEPING MANAGEMENT ASSISTANCE WITHOUT TRAJECTORY CONTROL ASSISTANCE
PASSENGER COMPARTMENT SOUNDPROOFING PASSENGER COMPARTMENT SOUNDPROOFING BULKHEAD + CONSOLE
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
DRIVER SEAT CONTROL MANUAL DRIVER’S SEAT CONTROL
FRONT PASSENGER SEAT CONTROL MANUAL FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT BACK WITH ANGLE ADJUSTMENT AND LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENT WITHOUT FRONT PASSENGER’S SEAT ADJUSTMENT
INT. UPHOLSTERY ELEMENTS HORIZON ROOF TRIM
FRONT SEAT ARMREST FITTED WITH ARMREST
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
HEADLAMP BULBS ECO LED
REAR WINDOW LIFT SEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READER LKA STRUCTURAL EDGE
DISPLAY 10-INCH COLOUR HD TOUCH SCREEN
COURTESY MIRROR DRIV OCCULT+PASS OCCULT W/O LIGHT
FOOTREST DRIVER’S FOOTREST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG FR CHEST/PELVIS SIDE AIRBAG+FR/RR CURTAIN
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
WIFI WITHOUT WIFI
STORAGE (DRIVING POSITION) LOWER STORAGE COMPARTMENT
RADIO RECEIVER ANALOGUE + DAB RADIO RECEIVER
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL WITH GEAR CHANGE
DRIVER’S SEAT HEIGHT CONTROL DRIVER’S HEIGHT ADJUSTER HEIGHT ADJUSTMENT
INTERIOR REAR VIEW MIRROR DAY-NIGHT INTERIOR MIRROR
CARPET COVER W/O CARPETMAT
LOAD SPACE STORAGE FIXED FLOOR STORAGE COMPARTMENT
TUNER RADIO MONO RADIO TUNER
OBSTACLE DETECTION SYSTEM REAR RADAR OBSTACLE DETECTOR + TRAJECTORY
TRIM ADAPTATION POLYCAR KNOB+PAINTED INSERT+PVC GAITER
FLOOR MAT W/O CARPETMAT
RADIO FREQUENCY RADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1
LOCKING CONTROL NORMAL + AUTOMATIC LOCKING
STEERING WHEEL LEATHER COATED STEERING WHEEL
SEATING ASSOCIATED VARIANT LOWER SEAT ASSOCIATED VARIANT
DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
AUDIO PACK AUXILIARY SOCKET AUDIO PACK AUXILIARY SOCKET 1 USB TYPE C
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATOR ALTERNATOR CLASS 18 HEA
HORNS HORNS-HARMONY
BATTERY L3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTOR STTD STARTER
CEN. LOCKING REM CONTROL FREQUENCY 433.92 MHZ SUPER HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY) STANDARD PROVISION ELECTRICAL EQUIPMENT
BATTERY CHARGER WITHOUT ON-BOARD CHARGER
MULTIPLEXING NEA R1
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF LIGHTS
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
MODIF. DURING MODEL YEAR WITHOUT MINOR MODIFICATIONS
HEAT PUMP FUNCTION WITHOUT HEAT PUMP FUNCTION
CONDENSER (SPECIFICATIONS) CONDENSER 19,3DM2 THICKNESS 12
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
AIR CONDITIONING PIPES IHX TECHNOLOGY AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET SINGLE ACCESSORY SOCKET
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTS UPPER REINFORCED SIDE IMPACT PROTECTORS
SET OF KEYS SET OF BADGE KEYS + BACK-UP KEY
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
P4A 9842082399
General information
TRIM LEVEL HIGH LOW
BADGE WITHOUT BADGE
TRIM LEVEL HIGH LOW
Fuel supply-Engine
CAPACITY 1500 CM3
GEARBOX TYPE ML6C
Body fittings
HORNS HORNS-HARMONY
Interior fittings
WIFI WITHOUT WIFI
Electrical
HORNS HORNS-HARMONY
MULTIPLEXING NEA R1
Miscellaneous
LABEL WITHOUT LABEL
emirock
What is the package for this car? Allure?
