Renault Wind boot lid does not open
Judgemental
Unread post by Judgemental »
The boot on my Wind will not open when release button pressed. I have read that this is due to water affecting the micro switch. Can this be cured or does it need changing? Car normally garaged but has spent wet week outside.
x 8126
Re: Renault Wind boot lid does not open
The first thing I'd do is to spray the switch are with a water repellant spray, allow it to dry and then try again. If you are lucky you may get a result and then you need to protect the switch with a waterproofing spray. If it doesn't work and you are happy with the wiring to the switch then yes it may need replacing. :)
