Ds3 quarterlight
Paulmallard+
Ds3 quarterlight
Need some help replacing quartlight window on my ds3,found the top 2 pop rivets but looki ng at the replcement there is also a fixing at the bottom,but how do i get access to that?
- x 8167
Re: Ds3 quarterlight
Which year is your car and which quarterlight?
- x 8167
I am afraid I cannot offer any help as my backup system is for cars up to 2012. Hopefully someone else will see your post and help you out. Good luck
Paulmallard+
Thanks for trying,just wondering if the bottom fixing just hooks over a stud
PaulC5
- x 717
Whilst being a 2013 car, when did the model first come out since if before 2012 then mickthemaverick might be able to help.
- x 8167
Good thinking Paul, this is the diagram of the pre 2013 windows which show the quarterlight to be on a stem, presumably fixed inside the door. Hope it helps
Paulmallard+
Thank you,looks the same still not 100% on the bottom fix,just have to bite the bullet drill out the top two and see what happens!
