DS3 Ramdon engine warning lights
Hortsy
Unread post by Hortsy »
We have a DS3 1.6 diesel 2018. We are getting Ramdon engine warning lights on when driving. Outside temperature reading wrong,handbrake fault,service light on,tyre pressures, low ad-blue warning even though tank is full. Seems worst in wet weather ? Fuse box is dry. Any ideas thanks
x 8166
Re: DS3 Ramdon engine warning lights
Scan the system for fault codes, carry out a BSI reset following the procedure below, clear the codes and then start from a clean sheet and see which codes come back. viewtopic.php?p=601679#p601679
PaulC5
x 717
Unread post by PaulC5 »
A topic on adblue to read viewtopic.php?t=85001 It can be worth the £10 cost of adding Wynn's adblue crystal clean and protect.
The outside temperature sensor in a mirror housing might need replacing and this if faulty can cause some other things such as air con not working.
