Peugeot 508 SW Mk2 2.0 Blue Hdi disc caliper to axle bolt torque
johnny1901
(Donor 2026)
Unread post by johnny1901 »
Hello,
I have 2021 Peugeot 508 SW Mk2 2.0 blue hdi VIN VR3**************[VIN obfuscated, can be read by forum staff].
I'm replacing the front and rear discs and pads and to do this you need to remove the disc caliper from the axle. Can anyone provide the tightening torque settings for the bolts which hold the calipers to the front and rear axles? Also the bolts for the pad retaining frame (which moves on the two sliders) if available?
I'm a subscriber to the forum.
Cheers,
John
x 8122
Re: Peugeot 508 SW Mk2 2.0 Blue Hdi disc caliper to axle bolt torque
Hello Johnny,
Unfortunately I can only access information for cars up to 2012 so yours is too new for me. However there are members with access to the information you need and hopefully one of them will see your post and help you out. :)
johnny1901
(Donor 2026)
Thanks Mickthemaverick for your response. I'll see if anyone can provide the figures
PaulC5
x 686
Unread post by PaulC5 »
Autodoc have tutorials which give torque values, as an example https://club.autodoc.co.uk/pdf-manuals/ ... -guide.pdf
The torque values in it for the rear caliper and pad carrier bolts seem similar to ones for cars I have worked on.
