BOXER 3 AIR BAG FAULT
JOE+TECH
x 4
Unread post by JOE+TECH »
Hi got peugeot boxer 3 with air bag fault,3 codes set
1 u0019 can fault
2 u 1703 comms with instrument panel
3 Bo100 ecu internal fault
No 3 I think is common fault ( ECU REPAIR) Let me know if you think different
What I would like if possible, a wiring diagram for air bag system please to help me check out unit
VIN No=VF3**************[VIN obfuscated, can be read by forum staff]
Thanks JOE
x 8151
Re: BOXER 3 AIR BAG FAULT
Hi Joe, Unfortunately I cannot find the diagram from the VIN as we have no access to the Stellantis system at the moment to look up the Vin. However if you can provide the year, RPO from the tyre sticker on the door pillar and provide the information indicated by the questions in the pics in the post linked below (it was for a 207 so substitute as necessary) I may be able to help: :)
viewtopic.php?p=861412#p861412
JOE+TECH
x 4
Some information regarding wiring diagram for boxer3 air bag system
2016 YEAR
CAMPER VAN
DRVERS AND PASSENGER AIR BAGS
SEAT BELT PRETENSIONERS
DIESEL ENGINE
Hope this helps , Thanks JOE
x 8151
Hi Joe,
I'm sorry to say I can't help as I only have access to a backup Servicebox which covers vehicles up to 2012. You will need help from a member with their own access to the current system for your van. Hopefully someone will pick it up and help out. Good luck :)
