Good evening all I’m hoping for some help and advice, I’ve got a 2010 Citroen Berlingo 1.6, it’s a non start, I’ve plugged my scanner in, and I’m not able to connect to the ECU, I’ve checked the usual suspect, fuse, all fine with that, I’m just wondering if someone could help on maybe what wires to check at the ECU to see if it’s getting a 12v feed, look forward to any help as I’d love to get my van back on the road
Thank you
No ECU comms
- x 8141
Re: No ECU comms
This is the starting diagram for a 2010 Berlingo, hopefully it will help. You may need to refer to the guide in this link to decipher the diagram!! Good luck
