Build sheet by VIN Number Peugeot e 3008 GT
nordicdust
(Donor 2026)
Unread post by nordicdust »
Hello Good people.
I am planning to buy a used car from a dealer.
It is a Peugeot e 3008 GT With GT-Pack and much more.
The car is imported, and the dealer has no Build Sheet on it.
The dealer's system in Denmark can not pull a Build Sheet before it is registered to a buyer, me.
But the car is listed with everything and I would like to be sure that this is correct before buying the car.
Can someone Pull a Build sheet on this VIN number please: VR3**************[VIN obfuscated, can be read by forum staff]
:-D
x 8111
Re: Build sheet by VIN Number Peugeot e 3008 GT
Unfortunately the staff don't currently have access to the Stellantis system to download build sheets. However hopefully one of the members with their own access may see your post and be able to help. :)
nordicdust
(Donor 2026)
Thanks, that would be great.
nordicdust
(Donor 2026)
Should I give up hope on that Build Sheet ?
It would be great if someone could help :-)
x 1056
Unread post by wheeler »
Here you go
Vehicle characteristics
Vehicle family 3008 (P64)
AS/RP N° 17328 89 3 0365
Warranty Start Date 28/05/2024
Engine serial number 10 7T0K 5003880
BER e2*2018/858*00064*02
Traction Battery N° AC0G0003352
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 3008 (P64)
SILHOUETTE 5-DOOR CROSS OVER
TRIM LEVEL UPPER MEDIUM
ENGINE ELECTRIC MOTOR ZLC 157KW BATTERY M
TRANSMISSION AUTOMATIC GEAR-BOX
PAINT TYPE PAINTED METALLIC EXT TRIM TYPE
BODY COLOUR TITANIUM GREY PAINT
INTERIOR TRIM TYPE NAPPA LEATHER "4H"
UPHOLSTERY COLOUR "FX"
GEARBOX (CHARACTERISTICS) REDUCTOR
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) ELECTRICAL VEHICLE
ROOF (EXT. ASPECT) BLACK PEARL ROOF
PRE-EQUIPMENT FOR CONVERSION WITHOUT PRE-EQUIPMENT FOR CONVERSION
OTHER BADGE ELECTRIC MOTOR ADDITIONAL BADGE
BADGE GT
STEERING VARIABLE POWER STEERING
Fuel supply-Engine
FAN 1-SPEED FAN 170W VARIABLE DYNAMIC AIR SHUTTER
DRIVE TRAIN ELECTRIC DRIVE TRAIN
TANK FILTER CITHOUT RESERVOIR FILTER
STOP AND START WITHOUT STOP AND START
DRIVE BATTERY TRACTION BATTERY 85KWH 12S 1P8S NMC622 BYD
FUEL SUPPLY ALIMENTATION ELECTRIQUE
FUEL FILLER CAP WITHOUT FUEL FILLER CAP
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL WITHOUT FUEL
EMISSIONS STANDARD (ENGINE) WITHOUT ENGINE EMISSION CONTROL
FUEL PIPE FIXINGS W/O FIXING FUEL PIPING
SPEED SENSOR SIGNAL FRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY WITHOUT
CATALYTIC CONVERTER NOT AFFECTED
FUEL TANK FUEL TANK WITHOUT LOCATING TAB
FUEL TANK INSULATION WITHOUT FUEL TANK INSULATION
COOLING MOTOR RADIATOR 28DM2 - THICKNESS 21 BRAZED ALU
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
VEHICLE TECHNICAL DEPOLLUTION ELECTRICAL
PARTICLE FILTER WITHOUT PARTICLE FILTER
Gearbox Transmission
GEARBOX TYPE RGML TYPE GEARBOX
FINAL DRIVE RATIO FINAL DRIVE RATIO 19 X 68
WHEEL STYLE ALU WHEEL DESIGN03 19 INCH
CLUTCH WITHOUT CLUTCH
SEAL, WHEEL END NOT AFFECTED
SEAL, DIFFERENTIAL END NOT AFFECTED
RIM/TYRE SIZE 19 INCH TYRE FIT
TYRE (SIZE, TYPE) TYRE 235/55 R19 105V -3PMSF
DRIVING WHEELS 2 DRIVEN WHEELS
WHEELS FITTED WHEEL 8J19ET43
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR INDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
Suspension-Steering-Brakes
BRAKE ASSOCIATED VARIANT ESP BOSCH 9.3 HSM
STEERING (OPERATION) HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) PEDAL ALUMINIUM
BRAKING ASSISTANCE IN REVERSE GEAR COLLISION WARNING - RCTA
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR STIFFNESS 28250 NM/RAD
ANTI-THEFT DEVICE ANTI-THEFT USING ELECTRIC ANTI-THEFT DEVICE
STEERING COLUMN MANUALLY ADJUSTED STEERING COLUMN
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR STIFFNESS 52500 NM/RAD
TRACTION CONTROL GRIP CONTROL TRACTION CONTROL
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
SUSPENSION NORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
Body fittings
TOWBAR TRAILER PRE-EQUIPMENT
HORNS HORNS-HARMONY
PAYLOAD NORMAL PAYLOAD
DECORATION (PAINTED) GLOSS BLACK DECOR
SIDE MOULDINGS (TYPE) GLOSS BLACK PROTECTORS
SIDE MOULDINGS (DIMENSION) WITHOUT SIDE PROTECTORS + PEUGEOT SIDE SILL
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL TRIM
EXHAUST TAILPIPE WITHOUT EXHAUST TAIL PIPE
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
WASHER JET STANDARD SCREEN WASH JET
EXT. REARVIEW MIRROR COMP. FUNCTION DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
WINDSCREEN GLASS (TYPE) HEATED WINDSCREEN GLASS
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER WITHOUT REAR WIPER + CAMERA WASHING
FRONT PANEL BLANK CENTRAL + LOWER CLOSER
ROOF GLASS WITH SLIDING TILTING ROOF WINDOW ONE-TOUCH CONTROL ANTI-PINCH
SIDE LOAD DOOR WITHOUT SLIDING SIDE DOOR
BUMPER BUMPERS FR/RR DESIGN 05
NUMBER PLATE FRONT IMPLANTATION EUROPE LICENCE PLATE
FRONT FOGLAMP SANS FEU DE BROUILLARD AVANT
PANORAMIC VISUAL AID DIGITAL PANORAMIC VISUAL ASSISTANCE
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL WITHOUT SPARE WHEEL
EXTERIOR ACCESSORIES BODY COLOUR EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CURVED EXTERIOR MIRROR GLASS
SUN ROOF PULSE ELECTRIC SUNROOF
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE) ACOUSTIC WINDSCREEN
Interior fittings
SEATING ASSOCIATED VARIANT VARIANT ASSOCIATED WITH HIGH SEAT POSITION
DRIVER’S KNEE AIRBAG WITHOUT KNEE AIRBAG
SUPPLEMENTARY HEATER WITHOUT ADDITIONAL HEATING
AUDIO PACK AUXILIARY SOCKET AUDIO PACK AUXILIARY SOCKET 1 USB TYPE C
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT
ANTI-THEFT ALARM VOLUME + PERIMETER + LIFT
FRONT HEAD RESTRAINT FRONT HEAD RESTRAINT CONTROL 2-WAY INTEGRATED COND+PASS
REAR SEAT MONOCHROME REAR SEAT FX+FOLDING 40/20/40 SEAT BACK
SUPPLEMENTARY SEAT WITHOUT ADDITIONAL SEAT
BLIND SPOT DETECTION BLIND SPOT MONITORING + LANE CHANGE ASSIST
REAR SEAT ARMREST WITH REAR SEAT ARMREST
CABIN SEAT WITHOUT CAB SEAT
INT. LOAD RETENTION 4 LASHING RINGS
LUGGAGE COVER (TYPE) TRAY TYPE LUGGAGE COVER
RADIO TELEPHONE 2 SMARTPHONES
LUGGAGE COVER SHELF
REAR SEATBELT PYR SIDE REEL + 3 POINT CENTR + UNBUCKLED WARNING
FRONT SEATBELT PYROTECHNIC SEAT BELT WITH ALARM
CLIMATE (AMBIENT TEMP) VERY COLD COUNTRIES
AIR CONDITIONING AIR CON WITH AERO + RECIRC + ADDITIONAL OUTLET
CHILD LOCK MANUAL REAR CHILD LOCK
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GEAR SELECTOR GEAR LEVER ON THE DASHBOARD+SS WHEEL
GRAB HANDLES FRONT+REAR HANDLES+HOOKS+RETRACTABLE
CONSOLE LONG CONSOLE + REAR AIR DUCT
SUPPLEMENTARY SEAT ADJUSTMENT WITHOUT ADD SEAT ADJUSTMENT
DRIVING POSITION LEFT-HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
MIRROR LINK WITH MIRROR LINK
LOAD SPACE LIGHTING GLOVEBOX+LED FRONT CONSOLE
BOOT AND LOAD SPACE LIGHTING WITHOUT BOOT LIGHT
DASHBOARD EQUIPMENT DASHBOARD SLUSH+FABRIC ALU+CAST
INT. TRIM AND EQUIPMENT VARIATION STANDARD INTERIOR EQUIPMENT DRESSING
WORK TABLE WITHOUT WORK TABLE
INSTRUMENT PANEL (CHARACTERISTICS) PANORAMIC INSTRUMENT PANEL SCREEN 21 INCH HD
CHILD SEAT ANCHORING POINTS CHILDSEAT ANCHORS FR NO ISO NO TT/RR 2ISO+2TT
LOUDSPEAKER 5 FR SPEAKERS (2 TW + 2 FR + 1 CENT)
PROTECTIVE COVER WITHOUT PROTECTIVE BATTERY COVER
RADIO CONTROLS STEERING WHEEL AUDIO SYSTEM CONTROL
ADDITIONAL BLOWER WITHOUT ADDITIONAL PULSE
POLLEN FILTER ALLERGEN FILTER
LANE KEEPING MANAGEMENT ASSISTANCE LPA + SEMI-AUTO LANE CHANGE (SALC)
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT+ELECTRIC FRONT SEAT CUSHION ANGLE
DRIVER SEAT CONTROL DRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROL PASSENGER’S FR ELEC SEAT CTRL + CUSHION FRONT ADJ
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT ELECT LUMBAR SUPPORT+PNEUMATIC SIDE ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENT FRONT PASSENGER’S SEAT WITH ELECT LUMBAR SUPPORT+PNEUMATIC SIDE ADJUSTMENT
FRONT PASSENGER SEAT FOLDING W/O FOLDING PASS FRONT SEATING
INT. UPHOLSTERY ELEMENTS MISTRAL INTERIOR ROOF TRIM
FRONT SEAT ARMREST FRONT CENTRAL ARMREST
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM CONNECTABLE NAVIGATION SYSTEM
HEADLAMP BULBS LED BULB
FRONT WINDOW LIFT DRIVER+PASSENGER FRONT ELECTRIC WINDOW
REAR WINDOW LIFT 2 ELEC WINDOW FR
TRAFFIC INFORMATION READER LKA STRUCTURAL EDGE
DISPLAY PANORAMIC MONITOR DISPLAY 21 INCH HD
COURTESY MIRROR DRIVER’S AND PASSENGER’S COVERED MIRROR WITH LED
FOOTREST ALU DRIVER’S FOOTREST
CUSHION PADDING PADDING WITH PASSENGER DETECTION PAD
HEATING ELEMENT DRIVER’S SEAT+PASSENGER ROW1&2 + VENTILATED ROW1
FRONT LATERAL AIRBAG FR CHEST/PELVIS SIDE AIRBAG+FR/RR CURTAIN
FOOTWELL LIGHTING FOOTWELL LIGHTING WITH LED
REAR PASSENGER PROTECTION WITH RR PASSENGER PROTECTION
PASSENGER AIRBAG WITH AIRBAG ON PASSENGER SIDE
ADDITIONAL AIR CONDITIONING WITHOUT ADDITIONAL AIR CONDITIONING
ON-BOARD COMPUTER COMPUTER
EQUIPMENT PACK W/O EQUIPMENT PACK
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE) CHROME FINISH INSIDE DOOR HANDLE
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
FRONT SUN VISOR DRIVER’S+PASSENGER’S SIDE (WITH + W/O INSCRIPTION)
WIFI WITHOUT WIFI
RADIO RECEIVER ANALOGUE + DAB RADIO RECEIVER
REFRIGERATION RFTA REFRI - REFRI AUTO TEMP CONTROL
CRUISE CONTROL ACC3 DECEL0 + ACCEL0
DRIVER’S SEAT HEIGHT CONTROL ELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRROR FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
AIR CON./TEMPERATURE REGULATION WITH DUAL ZONE AIR CON/TEMP CONTROL
STORAGE (OTHERS) PLAIN STORAGE POCKET
CARPET COVER UPPER GT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE RETRACTABLE FLOOR STORAGE COMPARTMENT
REAR SEAT PADDING WITHOUT RR PASSENGER DETECTION
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT/REAR/SIDE RADAR OBSTACLE DETECTOR + TRAJECTORY
LATERAL BLINDS WITHOUT SIDE BLINDS
RADIO FREQUENCY RADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1
STEERING WHEEL PERF FULL GRAIN LEATHER STEERING WHEEL GT INSERT
Electrical
LIGHTING OF LAMPS AUTO LIGHTING + ADAPTIVE SWITCHING
ALTERNATOR WITHOUT ALTERNATOR
HORNS HORNS-HARMONY
BATTERY (FITTING) STANDARD
BATTERY BATTERY L2 680A 60AH VRLA2 AGM PB
STARTER MOTOR WITHOUT STARTER MOTOR
SPECIAL LIGHTING FRONT DAY RUNNING LIGHT (DRL)
CEN. LOCKING REM CONTROL FREQUENCY 433.92 MHZ SUPER HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY) STANDARD PROVISION ELECTRICAL EQUIPMENT
BATTERY CHARGER THREE-PHASE 11 KW ON-BOARD CHARGER
MULTIPLEXING MULTIPLEXING NEA R1.1
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENT WITH BOSCH GENERATION 4 BATTERY CHARGE MEASUREMENT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
MODIF. DURING MODEL YEAR WITHOUT MINOR MODIFICATIONS
HEAT PUMP FUNCTION HEAT PUMP TYPE ARCHI COMPACT V1
CONDENSER (SPECIFICATIONS) CONDENSER 25DM2 - THICKNESS 18 EVAPOCONDENSER
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
AIR CONDITIONING PIPES STANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET TRIPLE ACCESSORIES SOCKET
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTS UPPER REINFORCED SIDE IMPACT PROTECTORS
SET OF KEYS SET OF BADGE KEYS + BACK-UP KEY
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
x 1056
Eller på dansk?
Køretøjets data
Produktlinje 3008 (P64)
OPR-nr 17328 89 3 0365
Dato for garantiens start 28-05-2024
Motorens Serienummer 10 7T0K 5003880
NRE e2*2018/858*00064*02
Drivbatteri nr. AC0G0003352
Generel information
PRODUKTTYPE PRIVATBIL
KOMMERCIEL TYPE/KOMPONENT TYPE PEUGEOT
MODEL 3008 (P64)
KARROSSERITYPE 5-DØRS CROSS OVER
UDSTYRSNIVEAU ØVERSTE MELLEM
MOTOR ELMOTOR ZLC 157KW BATTERI M
TRANSMISSION AUT.GEAR MED VARIATOR
LAKTYPE TYPE UDVENDIG BEKLÆDNING METALLAK
KARROSSERIFARVE TITANIUM GREY-LAK
INDTRÆK TYPE NAPPALÆDER "4H"
FARVE PÅ BEKLÆDNING "FX"
GEARKASSE (TEKNISKE DATA) REDUKTIONSGEAR
DEFINITION KOMMER SENERE PRODUKT INITIALE
MOTOR (TYPE) ELEKTRISK BIL
TAG (UDVENDIG FORM) TAG I FARVEN NOIR PERLA NERA (SORT)
KLARGJORT FOR OMBYGNING UDEN KLARGØRING TIL OMBYGNING
EKSTRA MONOGRAM EL-MOTOR EKSTRA BADGE
MONOGRAM GT
Data for køretøj
STYRETØJ SERVOSTYRING VARIABEL
Motorforsyning
VENTILATOR VENTILATOR 1 HASTIGHED VARIA 170 W AERO DYNAMISK SPJÆLD
DRIVLINJE ELEKTRISK DRIVLINIE
TANKFILTER UDEN FILTER I TANK
STOP OG START UDEN STOP OG START
DRIVBATTERI DRIVBATTERI 85KWH 12S 1P8S NMC622 BYD
FORSYNING ALIMENTATION ELECTRIQUE
DÆKSEL BRÆNDSTOFTANK UDEN BRÆNDSTOFDÆKSEL
FØLER FOR VAND I DIESELOLIEFILTER UDEN DETEKTOR VAND I BRÆNDSTOFFILTER
BRÆNDSTOF UDEN BRÆNDSTOF
ANTI-FORURENING (MOTOR) UDEN ANTIFORURENING MOTOR
FASTGØRELSE BRÆNDSTOF RØRSYSTEM UDEN FASTSPÆNDING BRÆNDSTOFKANAL
STIK FOR HASTIGHEDSSENSOR HJULFØLER FORAN MED HALL-LIGNENDE SIGNAL OG AKTIV HJULFØLER BAG
SLAGVOLUMEN UDEN
KATALYSATOR IKKE BERØRT
BRÆNDSTOFTANK BRÆNDSTOFTANK UDEN BRÆNDSTOFSIKRING
ISOLERING BRÆNDSTOFTANK UDEN LYDISOLERING TANK
MOTOR KØLING KØLER 28DM2 - TYKKELSE 21 ALU-LODDET
OPVARMNING AF EGR UDEN OPVARMNING GASKREDS DÆKSEL
AUTO-DIAGNOSE EOBD MED AUTO-DIAGNOSTICERING "OBD"
ANTI-FORURENING TEKNIK BIL ELEKTRISK
PARTIKELFILTER UDEN PARTIKELFILTER
Gearkasse Transmission
GEARKASSE TYPE GEARKASSE AF TYPEN RGML
UDVEKSLINGSFORHOLD UDVEKSLINGSFORHOLD 19 X 68
HJULTYPE ALUHJUL DESIGN03 19"
KOBLING UDEN KOBLING
PAKDÅSE HJULSIDE IKKE BERØRT
PAKDÅSE TRANSMISSIONSIDE IKKE BERØRT
FÆLG/DÆK STØRRELSE 19" DÆKMONTERING
DÆK (STØRRELSE, TYPE) DÆK 235/55 R19 105V -3PMSF
DRIVENDE HJUL 2 WD
MONTEREDE HJUL HJUL 8J19ET43
HJUL (TYPE) MONTAGE HJUL LETMETAL 1
DÆKTRYK INDIKATOR INDIREKTE DÆKTRYKREGISTRERING UDEN LOKALISERING
Affjedring Styretøj Bremser
TILKNYTTET VARIANT BREMSER ESP BOSCH 9.3 HSM
STYRETØJ (FUNKTION) ELEKTRISK SERVOSTYRETØJ, DOBBELT DREV, HIGH POWER
PEDALER (TYPE) ALUPEDAL
SERVOBREMSNING I BAKGEAR KOLLISIONSADVARSEL - RCTA
ABS-SYSTEM ABS
KRÆNGNINGSSTABILISATOR BAG BAGESTE KRÆNGNINGSDÆMPER HÅRDHED 28250 NM/RAD
RATLÅS SIKRING MOD TYVERI MED ELEKTRISK TYVERISIKRING
RATSTAMME RATSTAMME MANUEL JUSTERBAR
KRÆNGNINGSSTABILISATOR FOR FORRESTE KRÆNGNINGSDÆMPER HÅRDHED 52500 NM/RAD
ANTI-SPINFUNKTION GREBSTYRING TRAKTIONSSTYRING
BREMSETYPE VENTILEREDE SKIVER FORAN/SKIVER BAG
AFFJEDRING AFFJEDRING NORMAL
AFFJEDRING (TYPE, OPBYGNING) METALOPHÆNG
ESP MED ESP-SYSTEM
Udstyr Karrosseri
ANHÆNGERTRÆK ANHÆNGERTRÆK BESLAG
HORN HORN INDSTILLET
NYTTELAST NORMAL NYTTELAST
DEKORATION (MALET) SKINNENDE SORT UDSMYKNING
SIDE PYNTELISTER (FORM)S BESKYTTELSER BLANK SORT
SIDE PYNTELISTER (DIMENSIONER) UDEN SIDESTØDLISTER + PEUGEOT PANELBESKYTTELSE
HJULKAPSEL (TYPE) UDEN HJULKAPSEL
AFGANG UDSTØDNING UDEN RØRHALE
EKSTRA BESKYTTELSE (UNDER MOTOR) UDEN EKSTRA BESKYTTELSE UNDER MOTOR
SPRINKLERDYSE TIL RUDE STANDARD SPRINKLERDYSE
SUPPLERENDE FUNKTION SIDESPEJL ELEK. NEDFÆLDELIG FØRER+PASSAGER+DIODE+BAKGEAR+HUKOMMELSE
FORRUDE (TYPE) EL-FORRUDE
VINDUESVISKER FOR VINDUESVISKER FOR MED REGNSENSOR
VINDUESVISKER BAG UDEN BAGRUDEVISKER + KAMERAVASKER
BLÆNDPROP FRONT MIDTERSTE + NEDERSTE LUKKEPROP
TAGRUDE MED FORSKYDELIG TAGRUDE, KAN ÅBNES PÅ KLEM, SEKV.STYRING OG ANTIKLEM
SIDEDØR I LASTRUM UDEN SKYDEDØR SIDE
KOFANGER FOR- OG BAGKOFANGER DESIGN 05
NUMMERPLADE EUROPÆISK NUMMERPLADE FORAN
TÅGELYGTE SANS FEU DE BROUILLARD AVANT
BAKKAMERA VISIO PARK 360 PANORAMAKAMERA
SIDESPEJL (VENSTRE SIDE) SIDESPEJL EL-OPVARMET FØRER EL BETJ
SIDESPEJL (HØJRE SIDE) SIDESPEJL PASSAGER EL-OPVARMET EL BETJ
RESERVEHJUL UDEN RESERVEHJUL
UDVENDIGT TILBEHØR INDFARVET UDVENDIGT GREB
SIDESPEJL (FØRERSIDE) KONVEKS SIDESPEJLSGLAS
SOLTAG ELEKTRISK SOLTAG MED IMPULS
RUDE (FORM) TONET RUDE + MØRKTONET
RUDE (TYPE) LYDDÆMPENDE FORRUDE
Indvendigt udstyr
VARIANT AF SÆDE VARIANT TILKNYTTET HØJT SÆDE
KNÆAIRBAG VED FØRERSÆDE UDEN KNÆAIRBAG
TILSKUDSVARMER UDEN EKSTRA VARMESYSTEM
AUX-STIK AUDIO PACK AUDIOPAKKE AUX-STIK 1 USB TYPE C
TELEMATIKBOKS SELVSTÆNDIG TELEMATIKBOKS
TYVERIALARM VOLUMEN + PERIMETER + LØFTESIKRING
NAKKESTØTTE FOR NAK.STØT FORREST STYRING 2-VEJS INTEGRERET FØRER+PASS
BAGSÆDE BAGSÆDE MONO FX+RYG 40/20/40 RAB
EKSTRA SÆDE UDEN EKSTRA SÆDE
REGISTRERING AF BLIND VINKEL BLINDVINKELSYSTEM + VEJBANEASSISTENT
ARMLÆN BAGSÆDE MED ARMLÆN BAGI
KABINESÆDE UDEN KABINESÆDE
INDV. FASTGØRING 4 FORANKRINGSRINGE
BAGAGESKJUL (TYPE) BAGAGESKJULER, HYLDETYPE
RADIOTELEFON 2 SMARTPHONES
BAGAGESKJUL TA68
SIKKERHEDSSELE BAG PYROSIDERULLE+3 PUNKTSSELE+LAMPE IKKE SPÆNDT SELE
SIKKERHEDSSELE FOR PYROTEKNISK SELESTRAMMER MED ALARM
KLIMA (OMGIVENDE TEMP.) LANDE, MEGET KOLDE
KLIMAANLÆG A/C ANLÆGGET MED AERO+RECYCL+YDERL UDGANG
BØRNESIKRING MANUEL BØRNESIKRING BAGERST
GEARGRADUERING HASTIGHEDSINDDELING I KM/T
GEARFORBINDELSER GEARVÆLGER I INSTRUMENTBORDET+SS HJUL
KOMFORTUDSTYR (FARTGREB) HÅNDTAG FOR + BAG + KROGE + KAN TRÆKKES TILBAGE
KONSOL LANG KONSOL + LUFTKANAL BAGERST
INDSTILLING EKSTRA SÆDE UDEN JUSTERING AF EKSTRASÆDE
FØRERSIDE (FØRERPLADS) VENSTRESTYRET
MIRROR LINK MED MIRROR LINK
LYS I OPBEVARINGSRUM HANDSKERUM+FORKONSOL LED
LYS I BAGAGERUM/LASTRUM UDEN LYS I BAGAGERUM
UDSTYR TIL INSTRUMENTBORD INSTRUMENTBORD SLUSH+TEKSTIL ALU+STØBT
VARIATION BEKLÆDNING INDVENDIGT UDSTYR INDTRÆK STANDARD
LILLE ARBEJDSBORD UDEN ARBEJDSBORD
INSTRUMENTGRUPPE (TEKNISKE DATA) PANORAMISK INSTRUMENTGRUPPE SKÆRM 21" HD
FORANKRING BØRNESÆDER BØRNESÆDEFORANKRINGER FOR IKKE ISO IKKE FOR/BAG 2ISO+2TT
HØJTTALER 5 HØJTT. FORAN (2TW + 2 FORAN + 1 CENT.)
BESKYTTELSESOVERTRÆK UDEN BATTERIBESKYTTELSE
RADIO BETJENING RADIOKONTAKT PÅ RAT
EKSTRA BLÆSER UDEN EKSTRA BLÆSERMOTOR
POLLENFILTER ANTI-ALLERGIFILTER
HJÆLP TIL AT HOLDE VEJBANEN LPA + HALVAUTOMATISK VEJBANESKIFT SALC
HØJDEREGULERING HØJRE FORSÆDE ELEK. HØJDEREGULERING AF PASSAGERFORSÆDE+ELEK. HØJDEREGULERING FORAN
BETJENING VENSTRE FORSÆDE STYRING AF FØRERSÆDE M. HUKOMMELSE+JUSTERING AF SÆDEFORKANT
BETJENING HØJRE FORSÆDE KONTAKT TIL EL-BEJTENT PASFORSÆDE + SÆDEHÆLDNING
JUSTERING VENSTRE FORSÆDE FØRERSÆDE MED ELEKTRISK LÆNDEFAST. + PNEUMATISK SIDEREGULERING
JUSTERING HØJRE FORSÆDE PASSAGERSÆDE MED ELEKTRISK LÆNDEFAST. + PNEUMATISK SIDEREGULERING
NEDFÆLDNING HØJRE FORSÆDE UDEN NEDFÆLDNING FORSÆDE PASSAGER
ELEMENTER TIL INDVENDIG BEKLÆDNING BEKLÆDNING INDV. TAG MISTRAL
ARMLÆN FORSÆDE ARMLÆN FORAN I MIDTEN
CD UDEN MONTAGE COMPACT DISK
NAVIGATIONSSYSTEM NAVIGATIONSSYSTEM, DER KAN SLUTTES TIL INTERNETTET
PÆRE TIL FORLYGTE LAMPE MED LED
RUDEHEJS FOR FØRER+PASSAGER FORRESTE EL-RUDE
RUDEHEJS BAG 2 ELEKT RUDE FOR
TRAFIKINFORMATION LKA STRUKTURKANT
DISPLAY PANORAMISK MONITORDISPLAY 21" HD
MAKE-UP SPEJL SPEJL I FØRER- OG PASSAGERSIDE MED LED-LYS
FODSTØTTE ALUFODSTØTTE I FØRERSIDEN
POLSTRING PUDE POLSTRING MED FØLER FOR REGISTRERING AF PASSAGER
SÆDEVARMEELEMENT FØRERSÆDE+PASSAGERSÆDE RÆKKE 1&2 + VENTILERET RÆKKE 1
FORRESTE SIDEAIRBAG SIDEAIRBAG BRYST BÆKKEN FORAN+GARDINAIRBAG FORAN/BAG
LYS I KABINEBUND FODRUMSLYS MED LED
BESKYTTELSE PASSAGER BAG MED BESKYTTELSE I PASSAGERSIDE BAG
PASSAGER AIRBAG MED AIRBAG I PASSAGERSIDE
EKSTRA KØLING UDEN A/C
TRIPCOMPUTER MED TRIPCOMPUTER
UDSTYRSPAKKE UDEN UDSTYRSPAKKE
FRAKOBLING AF AIRBAG AIRBAG MANUEL AFBRYDELSE
INDVENDIGT DØRGREB (UDSEENDE) INDV. BETJENING AF DØR KROM
LYGTEJUSTERINGSMOTOR INDSTILLING AUTOMATISK FORLYGTER
SOLSKÆRM FOR FØRER+PASSAGERSIDE (MED + UDEN INDSKRI
WIFI UDEN WIFI
RADIO ANALOG + DAB-RADIOMODTAGER
AIRCONDITION RFTA AFKØL - AFKØL AUTO TEMP STYRING
FARTPILOT ACC3 DECEL0 ACCEL0
HØJDEREGULERING VENSTRE FORSÆDE ELEKTRISK FØRERSÆDEHEJS
BAKSPEJL FRAMELESS BAKSPEJL MED NEDBLÆNDING
REGULERING KLIMAANLÆG/TEMPERATUR MED KLIMAANLÆG/TEMP TO ZONER
OPBEVARINGSRUM (ANDRE) OPBEVARINGSRUM SÆDELOMME
MÅTTE (UDSEENDE) UPPER GT
FØRERAIRBAG AIRBAG FØRERSIDE
OPBEVARINGSRUM LASTRUM OPBEVARING AFTAGELIG VOGNBUND
POLSTRING BAGSÆDER UDEN REGISTRERING AF BAGSÆDEPASSAGER
RADIO TUNER BI RADIO TUNER
PARKERINGSHJÆLP FORRESTE/BAGESTE RADAR/SIDERADAR REGISTRERING AF FORHINDRINGER + BANE
GARDINER FOR SIDERUDER UDEN SOLGARDIN SIDE
RADIOFREKVENS RADIOFREKVENS AMT6_FMT4-50-DIAFTAPSTMC_DABT1
RAT LÆDERRAT AF FULDNARVET LÆDER PERFORERET INDLÆG GT
Elektricitet
LYGTETÆNDING AUT. TÆNDING + ADAPTIV KONTAKT
GENERATOR UDEN GENERATOR
BATTERI (MONTERING) STANDARD
BATTERI BATTERI L2 680A 60AH VRLA2 AGM PB
STARTER UDEN STARTMOTOR
SPECIALLYS FORRESTE KØRELYS (DREJELYGTER)
FREKVENS FJERNBETJENING CENTRALLÅSESYSTEM 433,92 MHZ SUPER HETERODYNE
EL-UDSTYR (LEVERANDØR) ELEKTRISK UDSTYR STANDARD LEVERING
BATTERIOPLADER INDBYGGET LADER 11 KW TREFASET
MULTIPLEX-SYSTEM MULTIPLEX-SYSTEM NEA R1.1
OPLADNING AF EL-BIL UDEN STIK OPLADNING AF BIL
MÅLING AF BATTERILADNING MED BOSCH GENERATION 4 BATTERIOPLADNINGSMÅLING
Fabrikanter
Diverse
VARIANT KRITERIE, KUNDEKONCEPT STANDARD
ÆNDRING I LØBET AF MODELÅR UDEN MINDRE ÆNDRING
VARMEPUMPEFUNKTION VARMEPUMPE TYPE ARCHI KOMPAKT V1
KONDENSATOR (SPECIFIKATIONER) KONDENSATOR 25DM2 - TYKKELSE 18 EVAPOKONDENSATOR
ALM. DIESELMODEL ATMOSFÆRE NORMAL
KONSTRUKTØRPLADE TYPESKILT EU + NY LOV
ETIKETTE UDEN MÆRKAT
KØLESLANGER/-RØR STANDARD KØLESLANGER/-RØR
STIK RADIOAFLYTNING TREDOBBELT TILBEHØRSSTIK
KØRSELSSIDE KØRSEL I HØJRE SIDE
SIDEKOLLISION SIDEFORSTÆRKNING ØVERST
NØGLESÆT NØGLERINGSSÆT + EKSTRA NØGLE
KØLEMIDDEL KØLEMIDDEL 1234 YF
FØRSTEHJÆLPSUDSTYR PUNKTERINGSKIT
KØRSEL BONNE ROUTE ///
HASTIGHEDSKONTROL UDEN FARTOVERVÅGNING
nordicdust
(Donor 2026)
Thanks Wheeler
That made my day, thanks again I really appreciate it.
