Can anyone tell me what should cx gti turbo II bort computer with four displays should show:
first clock?
second temperature of engine?
third fuel consumtion?
fourth outside temperature?
cx lcd display
DoubleChevron
You should have starting from the left of the dash:
--Oil Temperature
--Water temperature
--On board computer (you will need a manual to work out how to use this... One of it's features in a clock. It's probably showing "Opt" or something similar). Lift the left door on the center console to find the keypad.
--Outside temperature.
These displays have probably lost segments, to fix I suggest you follow the instructions here:
http://www.algonet.se/~frenchie/cx/CXdisplay.html
good luck !!
Shane L.
--Oil Temperature
--Water temperature
good luck !!
Shane L.
