Does anybody know where it is?
I need to crank the engine over without it starting and figured this would be the easiest way however I've no idea where the relay is!
Anyone?
Thanks.
DS3 1.6 e-hdi fuel pump relay location?
- x 8167
Re: DS3 1.6 e-hdi fuel pump relay location?
What year is the car?
- x 1499
The e-HDI doesn't have an electric fuel pump. If you don't want it to start, unplug the injectors, or the crank sensor.
- x 8167
Good point Richard, I missed the 'e'
sixfoottwo
Thanks, probably why I can't find it then!!RichardW wrote: 31 Jan 2026, 13:57 The e-HDI doesn't have an electric fuel pump. If you don't want it to start, unplug the injectors, or the crank sensor.
I was thinking about unplugging the injectors but won't that spray fuel on cranking?
- x 8167
I think Richard meant unplugging the electric feed to the injectors, not the fuel feed!
sixfoottwo
Yeah, silly me its been a long day!mickthemaverick wrote: 31 Jan 2026, 14:25 I think Richard meant unplugging the electric feed to the injectors, not the fuel feed!![]()
sixfoottwo
Bump!
OK, so I've managed to unplug the connectors for all injectors and managed to test cylinder 4 and 3 however 1 and 2 are not possible without disconnecting the fuel filter lines because of the access needed resulting in diesel spraying out on cranking !
Any ideas on this?
Any ideas on this?
sixfoottwo
Finally managed to test all the cylinders without spraying fuel ! 3 coming back around 410 and one is showing 400 so guessing all OK.
