Problem starting the car
Antimnemonic
New User
Unread post by Antimnemonic »
Hi everyone. I’ve run into a problem: the car doesn’t start on the first try, but it always starts on the second. This happens at different times but not consistently. Has anyone had this issue? The fuel pressure has been checked, the spark plugs and coils have been replaced, the timing belt has been changed, and the fuel filter as well. I’m thinking of replacing the crankshaft position sensor during the next oil change. This issue is quite common with the 1.2 PureTech, but there doesn’t seem to be a clear solution. Thanks for your help
wurlycorner
x 271
Re: Problem starting the car
Unread post by wurlycorner »
Hi
Is this something you've been diagnosing yourself, or have garages been looking at it?
Iain
CX DTR T2 Safari (silver)
PaulC5
x 685
Unread post by PaulC5 »
Have you checked the battery in case it needs charging up.
