Citroen c3 vtr shorted the battery now it's dead
Marksmachines
Unread post by Marksmachines »
Hi everyone im new here, I done a stupid thing whilst changing my old battery i accidentally touched both terminals now the whole car is dead all the fises are good but the locked light is flashing, tried the reset but nothing please 🙏 help
x 8143
Re: Citroen c3 vtr shorted the battery now it's dead
Did you short the old battery or the new one? :) - or is 'changing' a misprint for 'charging' ? :)
Marksmachines
Charging old one to put back on mate
x 8143
OK, then if you had some sparks etc you have probably killed the battery completely. You need to fit a new battery, you may have to go into Repair section in Diagbox and tell the ECU it has a new battery and then carry out the BSI reset according to the link below. Good luck :)
viewtopic.php?p=601679#p601679
x 1056
Unread post by wheeler »
Did you check all the fuses including the maxi fuses hidden under the under bonnet fusebox?
