Thoughts?
I've read plenty of horror stories of them breaking quite easily but I need to remove them to insert my compression tester I've got hold of in order to see if the engines ok after issues!
What we thinking? Leave well alone??
DS3 Glow Plug removal?
- x 7959
Re: DS3 Glow Plug removal?
If the engine is performing ok without odd noises or leaks and no fault codes I'd leave well alone!
Mihael_M
- x 36
Since I don't know which engine it is, I assume that it is one of the diesels. Removing the glow plugs is always risky, especially if it is rarely done. But the glow plugs are 8 mm thread, how can the pressure gauge be attached? In gasoline engines, this is done instead of a spark plug. Is it not possible to measure here on the hole instead of the injector nozzle?
