Hello. Citroen C4 Picasso 2014, 1.6 diesel, semi-auto. I have strange problems with it. It won't start when clicking the start button. If the ignition is off, I press the brake and push the button. I can hear a click, like the starter is trying to turn the engine. Then a lot of faults on the dash start beeping. After it stops beeping, if I keep the brake pressed and try to start, it says on the screen, "Put the lever in N and press brake to start," although I'm pressing the brake and the lever is in N. If, with the ignition on, I short the starter to positive, it will start without a problem.
What I tried: changed a lot of brake switch sensors, checked all the fuses and relays. Changed the ground cable from gearbox to body, as it seemed a little broken. Changed wheel speed sensor, the fault remained the same.
Interesting faults:
BSI: B1418 00 Fault in seatbelt fastening information status for determining presence of driver
Engine ECU:
U1213 inter systems CAN - one of the parameters present in a data stream sent by the ABS/ESP is invalid
U0304 inter systems CAN - Error in length or prohibited value on transmission ECU data stream
Semi auto ECU:
P171A brake signal fault (switch/CAN) - CAN/by wire consistency
U1213 fault in information transmitted by ABS or ESP or Electric parking brake (EPB) ECU - incorrect value received
ABS:
C1391 00 Fault: engine torque not cleared - Not characterised
C003A:11 Rear right Wheel speed sensor - short circuit to ground
Power steering:
U1213 Communication fault between the ABS/ESP ECU and the Electric Power Steering (EPS) ECU
Additional info:
Gearbox ecu shows engine coolant temperature as -29C. Engine ecu shows gear lever position (A/T information) M, but it is on N. ABS ecu shows engine clearence dialog fault and Electro valve supply relay status faulty.
Can anybody help me and advise, what and where to search? Thanks
C4 Picasso 2014 won't start with button
- x 8119
Re: C4 Picasso 2014 won't start with button
From reading your post I got the feeling that you are pressing the start button without the ignition on. If that is the case then it won't start!!
Vikis
I wish that was the case — would’ve been an easy fix!
But really, if the ignition is off when pressing the button, I can hear the starter trying to start the engine for a second. If the ignition is on and then trying to start, nothing, just press the brake and put the lever on N
Vikis
I still have this problem. Could anyone help me, please?
