Another BPGA problem
OMG123
Hi all new owner to C4 GP 2016. Had it a month and straight into problems. Assume it is the BPGA as all the symptoms fit. Tried to check the plug but seems to be corroded into BPGA
. Question is are there any options? Not sure how big that piece of loom is. Can you buy a new electrical plug? Any help appreciated.
- x 8165
Re: Another BPGA problem
You may get some info from this video:
OMG123
Wouldn’t be much problem to replace it. Just the fact that the connector plug is corroded into it so need to splice in a new plug or a new piece of loom. Bit of a nightmare really. Thought someone on here might have gone through the same thing and found a solution. Thanks
