Hi all,
Does anyone know the piston ring end gaps for the 1.5 DV5 engine?
1.5 DV5 engine specs
- x 8085
Re: 1.5 DV5 engine specs
What model and year car is this from?, as that is needed to find info on the system.
David0440
Hi Mick,
Thanks for the response. The short answer is that it is actually a 2020 transit connect with the 1.5 ecoblue engine. However these Peugeot/Citroen/Ford DV5 engines are shared on lots of models (e.g Peugeot partner). The Ford database doesn’t specify this spec so was hoping either the Peugeot or Citroen alternatives did have that information.
Assuming if a 2020 Peugeot Partner was looked up it may have the info?
Really appreciate if you could help with this and I’m sure it would help anyone else that’s needs it in future on Peugeot, Citroen, Ford and Vauxhalls as I could not find the information anywhere online.
David
David
- x 8085
I understand your predicament David but I'm afraid I can't help as I only have access to information on vehicles up to 2012. However there are members with access to the latest vehicles' information and hopefully one of them may be able to help you out. Good luck
