Relay 2021 turbo issue
Will27
I have 2021 relay 2.2 blue engine DW12 with code p2563 turbo position sensor deviation , a local garage has changed couple of sensors but after couple of weeks fault comes back they can’t find a turbo boost sensor, I have some basic diag I can’t reset code but I tell it new Egr fitted it deletes stays of about a month now I’m thinking Egr sticking causing low boost ???
PaulC5
- x 701
Re: Relay 2021 turbo issue
On our 2007 C5 the turbo boost pressure was taken from the MAP sensor, however your Relay may be different.
Will27
Thanks the map sensor has been changed looking online looks like there is a vacuum operated turbo pressure sensor going to try and find it tomorrow
Will27
Had a look at turbo yesterday the actuator is electronic so does that mean the position sensor is built in the actuator no vacuum pipes ????
