2003 Berlingo blower not working,
Cornishpete
Unread post by Cornishpete »
Hello, im a long time observer, but now I could really do with a little help. My blower motor has suddenly stopped, I have searched my house for my Haynes manual but can't find it and coming to a stop. I have read that there should be fuses, but there are no tables in the fuse boxes, so have tested all the 40a ones as from searching these coukd be the feeds, I have pulled the connection off the rotary selection switch but seem to have no power.
Can anyone help with a diagram, mine only has two fuse boards and the only help I can find is for later models.
Many thanks
Pete
x 8129
Re: 2003 Berlingo blower not working,
In order to find the correct diagram you need to post the details of your Berlingo, year, engine, gearbox, body style. :)
Cornishpete
Hi, so it's a 2003 1.9 diesel multispace. Hope this helps
x 8129
Without gearbox or RPO number, I worked out around 09750, this is the best option I could find in my backup. :)
berlingo heater.pdf
Copied from Citroen Sedre Backup.
(2.58 MiB) Downloaded 59 times
With the aid of the info in the guide linked below you should be able to work it out. Good luck :)
viewtopic.php?p=782862#p782862
