Help - ABS Pump
Locost27
Help - ABS Pump
Unread post by Locost27 »
Good afternoon all
I have a 2012 Ds3 1.6 vvti which I am converting to a DS3 Cup Car.
I have had to do quite a bit of work to the car to get it to where i want it to be. As a result I had to take the pump off.
I want to make sure that I put the pipes back into the pump in the correct orientation.
Does anyone have a diagram or are able to tell me the correct order.
Many thanks for your help.
x 8167
Re: Help - ABS Pump
Hopefully you can work it out from this diagram: :)
DS3 - 0120 04 453065A - BRAKE PIPING ABS OPTIONAL.pdf
Copied from Citroen Service Box backup
(171.67 KiB) Downloaded 136 times
