Help coding massage and heated seats 508 II
thomas_magnum
Unread post by thomas_magnum »
Hi guys.
I'm having some trouble coding the massage and heated seats. I've retrofitted the seats from a 508 PSE into my 508 Hybrid. The only thing not working is the massage and heated function.
I've coded the buttons on the NAC and under the display (touch heated button).
I'm using Arduino and PyPSADiag application.
Can someone give me some help?
x 8122
Re: Help coding massage and heated seats 508 II
Hi and welcome. unfortunately I cannot help you here other than to suggest you find someone with Diagbox and see if they can be programmed from there. Good luck :)
