Nemo Still eating front tyres
ohspecial1
Unread post by ohspecial1 »
Hi Folks car got moted 5-6 jan
Advisory 3mm on front tyres
Spoke to the mot garage as i got them to fit tyres back in the summer 25
Front tyres seem to be suffering 5k on this set
Had the car about 3 years and got through 3 sets of front tyres
Back only changed once
Car has 49k on it now so have done about 24k miles since owning
Garage says get rid of it
this is an automatic/well automatic manual
Maybe need to try different brands
Had falkens 2 sets
now some chinise
x 8146
Re: Nemo Still eating front tyres
Try a better spec tyre is where I would go
x 2362
Unread post by MattBLancs »
Is the wearing even across the tread width or more on outer edge/ both edges?
How, err, "spirited" is your driving style?
Years ago I have had very cheap seemingly hard tyres that lasted ages (Wanli - they may be reformulated now and better than they were then!) but had poor grip, I've also had very cheap tyres that were ok for grip but so soft and soon wore out.
ohspecial1
I'm wondering if to pick some michelin or bridgestones or something
Just seems on the fronts
PaulC5
x 698
Unread post by PaulC5 »
The link to your earlier similar topic https://frenchcarforum.co.uk/forum/view ... 90#p852490
When choosing tyres see if manufacturers give an indication of expected miles.
x 2362
PaulC5 wrote: 10 Jan 2026, 12:58 The link to your earlier similar topic https://frenchcarforum.co.uk/forum/view ... 90#p852490
Thanks Paul,
Some questions answered, still some no answer:
Is tread wear even? No, inner and outer edges
Ohspecial1 =.
Agree with conclusions on other thread, low pressure is possible.
What pressures are quoted on the door pillar sticker? I'd guess a van would have loaded and empty figures even for the front that could be a fair variation.
Does your van run full mostly or not carrying much weight?
Do you keep on top of the pressure checking? Fortnightly? Monthly?
Have you tried upping the pressures a little to see if wear more evenly?
Thoughts on your own driving style? Laid back or setting new lap record on each trip?
x 2938
When one of my customers was suffering from poor mileage on his tyres Michelin service came out and weighed the vehicle and recommended tyres to replace them with, his tyres went from wearing out at around 3k miles up to 30k.
I don't know if they still offer that service but they do have a range of tyres specially for light commercials and a help chat line on their website.
https://www.michelin.co.uk/auto/browse- ... tegory/van
ohspecial1
MattBLancs wrote: 10 Jan 2026, 13:43
Thanks Paul,
Ohspecial1 =.
Hi Well its a people carrier but never carry any people
Mostly would carry mobility scooters so would be heavy but not massively
Surely wouldnt i see heavy ware on the rears
Dont check massively often
Well its a semi auto never going to be a rocket
These chinise its even
Falkens heavy on sidewalls
would be just me most of the time
PaulC5
x 698
Have you tried to check if your pressure gauge is accurate, ones on foot pumps are way out, a separate digital one might be best. No idea if ones at petrol stations are any good but the pressures are meant to be checked with cold tyres so driving before checking will result in pressures being set too low.
x 2938
PaulC5 wrote: 11 Jan 2026, 13:45 Have you tried to check if your pressure gauge is accurate, ones on foot pumps are way out, a separate digital one might be best. No idea if ones at petrol stations are any good but the pressures are meant to be checked with cold tyres so driving before checking will result in pressures being set too low.
Not sure about the rules now but when I ran my garage business and before when I worked for a dealership trading standards officers periodically at the same time as checking the petrol pumps for accuracy also checked the tyre pump gauge.
