C5 2003 Bluetooth
Spix
C5 2003 Bluetooth
What's better way for add Bluetooth module for my car
- x 8137
Re: C5 2003 Bluetooth
Cheapest and easiest way is to buy a Bluetooth module which also gives handsfree and simply connects to your car via the FM tuner. eg:
https://www.ebay.co.uk/itm/376464637304
Spix
Thank you.mickthemaverick wrote: 09 Jan 2026, 20:29 Cheapest and easiest way is to buy a Bluetooth module which also gives handsfree and simply connects to your car via the FM tuner. eg:
https://www.ebay.co.uk/itm/376464637304![]()
It possible change actual cd radio for example?
shtu
- x 78
The FM modules are a bit pants generally, but do work. It's certainly easiest.
Next step up is a bluetooth module that connects to the AUX input, eg, https://www.ebay.co.uk/itm/135366958588
Next approach - assuming you have an RD4 radio - is to replace with an RD45, not complex, but not entirely straightforward either. There's threads on here about that. https://frenchcarforum.co.uk/forum/viewforum.php?f=52
