Radiator cooling fan
Jd4467
- New User
Hello my engine radiator fan is constantly on and even stays on when ignition turned off and key removed. Even when car locked for up to 15 minutes. I have no idea why. Engine temp is ok. Thermostat recently changed. Ambient air temp sensor shows incorrect temperature intermittently
PaulC5
- x 712
Re: Radiator cooling fan
If the fan eventually goes off it might be the dpf was being regenerated. If it starts up as soon as the engine is started then it will be something else.
