Citroen c4 grand Picasso electric window problem
Citreonboy57
Hi need some help I have a 2016 grand Picasso 1.6 diesel the electric window switches from the drivers side have stopped working although the windows work from the other doors passenger and rear doors also all the mirror electrics won’t work either was wondering was it the drivers switch module unit not sure what the proper name for it wondered if anybody had encountered this thanks in advance
- x 5679
Re: Citroen c4 grand Picasso electric window problem
This has been seen in some C5s and was attributed to water ingress into the switch panel causing contamination and sometimes corrosion of the contacts.
I had it one one of my C5s and James (Hell Razor5543) found that the cure was to remove the switch panel, dismantle it and clean all the contacts with contact spray (Servisol) or isopropanol.
Aslo using the rubber (eraser) on a pencil on the contacts helps.
