Peugeot expert 6SP FWD-TF-80SC transmission
106reds1
Unread post by 106reds1 »
Hello just been into my local Peugeot dealer, they have given me rubber washers for the automatic transmission drain and fill plug I know the level plug torx 40 uses a small rubber o ring, but is this correct for the larger sump plug? It doesn't seem right to me any help would be appreciated.
Thanks.
x 8122
Re: Peugeot expert 6SP FWD-TF-80SC transmission
If you enter your reg in this site and then track down the washer you should discover if you have the right one: https://www.buycarparts.co.uk/oil-drain ... r/m-topran :)
