Performance figures
Post your Cit/Peu/Ren air conditioning queries or advice.
bernie
Performance figures
Unread post by bernie »
BX
Standing start - cold engine
Temperature probe in centre vent
Blower on max.
Start engine
Temp. 21 deg.C
A/c switched on
4 minutes later
6 deg.C
Bloody freezing[:D]
tomsheppard
Unread post by tomsheppard »
That sounds about right. 15 degrees is the right sort of drop. Try going into recirc. after 2 minutes
bernie
Gets better[:)]
On the road about 30mph[}:)] it go down to -2 deg.C[:D][:D][:D]
Yesterday I had a little fog coming from the vent, very spoooocky[}:)][}:)]
jkirkwood
Unread post by jkirkwood »
OK, that's BX's. Can I expect the same out of a Berlingo Multispace 2.0HDi? reason for asking is that mine is 15 months old and I'm sure it isn't anywhere near that, and slowly getting worse.
tomsheppard
From what we are told, the BX plant is around the most efficient you can get, so probably not. If you are not getting enough cooling, first check that the condenser isn't blocked with a paper bag or something. Then check the warranty to see if the a/c system is covered. You may need a regas but I'd be concerned if the system had lost a lot of gas in this time, which may point to a leaky system from new which I would insist that Citroen fix...
alan s
RIP 2010
x 6
Unread post by alan s »
.........also just watch that leaves and dust don't get between the condensor & radiator & foul up the air flow; that has to be kept clear at all times.
Loosen radiator and blow a Karcher or Gerni down between as well as through if possible just to be sure.
Alan S
