Door lock
hamid28shah
Door lock
Unread post by hamid28shah »
Not sure if anyone has come across this fault before. 2020 Peugeot expert central locking will lock all doors with the transponder fine. However it only unlocks the ns sliding door with the transponder. All other doors need to ge opened with the key in each lock. I have checked all fuses and selective door locking options all OK.
x 8126
Re: Door lock
Try a BSI reset before you go any further: :)
viewtopic.php?p=601679#p601679
hamid28shah
Re: Door lock
Hi, Happy new year. yes tried the hard reset nothing.
I unplugged all modules from all doors and a B1722 11 short to ground fault remained.. thinking it’s the BSI itself.
Esmotors
New User
Re: Door lock
Unread post by Esmotors »
I have same issue and fault code on my peugeot 2008 2021 model. Was you able to fix?
hamid28shah
Re: Door lock
Hi, no the car went away, I was later told it was a BSI, issue what about did you mange to fix sorry saw message late was away….
gazzaman2k
Re: Door lock
Unread post by gazzaman2k »
i have exactly same issue on 2020 berlingo mk3 :( hoping its not the bsi
hamid28shah
Re: Door lock
Did you manage to fix it?
