My car keys won't unlock the doors
x 8137
Re: My car keys won't unlock the doors
Is your car still under warranty?
x 8137
Then I'd take it back to the dealer and get them to sort out the keys for you. :)
x 1940
Unread post by Paul-R »
Try resynching the keys. Follow the procedure here at the end headed Reconnection:
viewtopic.php?p=601679#p601679
x 1940
You're going to have to dig about in your handbook to see if there's an option to change the way that the key buttons operate.
Huskyxantia
x 920
Unread post by Huskyxantia »
Max wrote: 22 Dec 2025, 22:15 That's interesting Paul because I have found that when I press the key unlock button the doors won't unlock but if I press the button on the boot door a few times it will unlocks which also then unlocks the doors so I'm guessing the keys unlock the boot door but not the car doors so maybe again I'm guessing would it have something to do with the service it had in October, the reason why I'm thinking this is a good few years back I had a 308 peugeot and on it's first service I had to take it back because of the spanner showing on the dash and found out that the car computer wasn't reprogram to let the car know that it was service
This is one of the reasons a relation of mine left psa, this little thing was to get people to go back and throw more money at them , I'd jump on them and make it clear this happend at the time of the service and get them to put it right, for free.
:-D
BusybeasDS
x 24
Unread post by BusybeasDS »
The very same happened to us with a 2022 C4.
I did all that you did, and in the end I found it was simply the main car battery low.
Everything else on car was unaffected, just neither key fob would function.
No error messages on dash or anything..
I had ours booked in also, months away and the alarm going off when the door was unlocked manually became an embarrassment.
So I needed to find a quicker solution..
I charged the main 12v battery up with a smart trickle charger, re-initialised the key to the steering column, then everything worked as normal.
Kept the car for almost year after and never had the key problem again.
Cancelled the dealership booking too.
Could be coincidence, but worth a simple try perhaps?
It is widely known that low main battery voltage / condition does cause some weird issues with PSA vehicles...
Cheers
Steve
x 1493
Has anyone been poking about in the fuse box? This sort of behaviour is what happens when the shunt fuse in the park position.
