Citroen C5 suspension working but very slowly
XantiaNonStarter
x 5
Unread post by XantiaNonStarter »
My Citroen 2007 C5 now takes ages to move between suspension positions. For example moving from the lowest position to the normal height takes 70s (It used to take 23s.) Could I ask, if this was your car what would you check first?
The battery is OK and I've gone through the LDS bleeding process.
Thanks for your help.
x 8137
Re: Citroen C5 suspension working but very slowly
Sounds like a faulty pump to me? :)
XantiaNonStarter
x 5
I'm glad you said that. That's what I thought also so I took the pump of the car and opened up the electric motor. I was hoping to see gunk in the motor that I could clean out. However all the wiring looks really clean :-(
x 8137
Rather than an electrical fault I was thinking a loss of pressure due to a leaky diaphragm or similar, I don't actually know the internals of the pump. :)
This video shows you the innards and there is a diaphragm and a number of seals involved but that's about all I can get from it!!
