2010 Citroen C3 Exclusive HDI LHS sidelight off
IainSmith
Unread post by IainSmith »
Vin VF7**************[VIN obfuscated, can be read by forum staff]
LHS sidelight is off with only 4.1 V at bulb holder.
Checked bulb/bulb holder and ok. Removed plug from rear of headlight and compared incoming voltage with RHS plug. Only difference is pin 1 which on good light is 13.8V and on bad light is 4.1 V. Can any one provide electrical drawing showing where this voltage is fed from.
Cheers
x 8137
Re: 2010 Citroen C3 Exclusive HDI LHS sidelight off
I think this is the diagram. The link below takes you to the Diagram interpretation information.: :)
C3 sidelights.pdf
Copied from Sedre backup
(659.88 KiB) Downloaded 90 times
viewtopic.php?p=782862#p782862
IainSmith
Thanks for the reply. Issue was found to be in the BSM with one of the connectors corroded. Replaced BSM and all good.
