PEUGEOT 308 2012 1.6 90HP 68KW
frankieyeha
can some1 tell me what the control module is its not getting any power.
- x 8124
Re: PEUGEOT 308 2012 1.6 90HP 68KW
Control module will depend on which ECU you were connected to ?
frankieyeha
its the 1 in my peugeot 308 1.6hdi 2012.
- x 8124
I meant which ECU you were addressing when that display came up. Using Diagbox you can select each ecu to interrogate and hence my question. I see you are using a different diag tool so I have no idea what it is referring to. You need to look in the manual for that tool to understand what it is showing you.
- x 1939
I'm guessing you mean the engine ECU (sometimes called the injection ECU). It actually stands for electronic control unit but is widely misused (including Wikipedia in places) to mean engine control unit. It's also sometimes called an ECM (electronic control module).
frankieyeha
il buy a diagbox.
frankieyeha
theirs no power going to the ecu il check the 20 amp fuse tomorrow car drives perfect.
Huskyxantia
- x 915
This a wind up ? No power to ecu but car drives perfect? Is your battery ok ?
Husky.
PaulC5
- x 693
If the car drives normally then what made you plug it in for a diagnostic ? If just done out of interest then it is possible there is absolutely nothing wrong. You could also try it when the engine is running in case the unknown Control Module then gets a voltage.
