Citroen c3 picasso 1.6hdi 2010
Taffyat007
Unread post by Taffyat007 »
Hi all long time reader can any one tell if my car has Eolys tank plz vin number VF7**************[VIN obfuscated, can be read by forum staff] engine number JBCL3039539. thank you
x 8144
Re: Citroen c3 picasso 1.6hdi 2010
Taffyat007
Trying to find out if my car has Eolys tank?
x 8144
Unfortunately I only have access to a backup of the Citroen ServiceBox which does not include vehicle build sheets so I cannot answer that for certain. However it is highly likely that it does have a DPF and hence an eolys tank or bag, have a look at this thread for guidance on how to tell: viewtopic.php?p=761730#p761730 :)
Taffyat007
Brilliant thank you
x 8144
I have been able to get the exhaust system parts diagram for your car which you can download from below. You will see that the car is fitted with a Particulate Filter and hence you will have a bag or tank which you will find under the car just in front of a rear wheel, probably the nearside but I can't remember which side on the C3, they do vary!!
C3 PICASSO - 0180 06 183075A - FRONT CATALYTIC EXHAUST MANIFOLD.pdf
C3 Picasso Exhaust system
(194.35 KiB) Downloaded 166 times
Taffyat007
Brilliant thank you
