Diagnostic report 308 2014
ivica001
Unread post by ivica001 »
Hi, can someone point me why i have this errors i am worried about Permanent and what can i do about it?
x 8137
Re: Diagnostic report 308 2014
I have a policy not to download PDF's from unknown sources so could you post the error codes yourself? :)
PaulC5
x 697
Unread post by PaulC5 »
I might have made a mistake looking at it but there seems to be a lot of things going on. As well as the fault codes it would be good to know what the symptoms are.
x 1468
Unread post by xantia_v6 »
Most of the fault codes are temporary or intermittent, so were not current when the test was run. Some of them look like the type of code that you get if an attempt has been made to start the car with a flat battery.
The best actions is to erase all of the codes and see which ones come back.
