My power steering warning light has come up on my dash upon inspection via a code reading I’m getting these two codes - c1415, c1414 wondering if anyone has had any experience or could shed some light on some solutions.
Many thanks
C3 Picasso Power Steering Error codes
- x 8130
Re: C3 Picasso Power Steering Error codes
Have you checked the level of your power steering fluid?
- x 8412
It's electric on a C3 Pic...
The error codes you have provided point to a major EPS system fail although the C1415 points more toward a rear wheel speed sensor fault.
Do you have any ABS/ECP malfunctions showing?
How did you get these error codes? If just an basic OBD reader then it may be worth getting a full Diagbox diagnostic carried out. It will give much more information and help nail down the source of the problem.
Do check the fuses supplying the power steering (EPS) and the fuse box. C3 Pics are well-known for water ingress into the engine bay fuse box due to blocked scuttle drains...
Reminds me, I must check mine.
