Citroen Berlingo 2016 Compression Values
Bro_D
Unread post by Bro_D »
Hi all
I have a 66 plate Citroen Berlingo 1.6hdi Adblue 8v
I recently had my cambelt strip teeth which I've posted about before. The van starts and drives fine but has no power so I decided to do a compression test.
My values for the cylinders are 230 - 240psi. The engine was cold when I did the test as I currently can't start it as I have a lot of things disconnected.
I've read that the values should be 300 - 400 psi but can't find a specific value and obviously every engine will vary.
So I guess my question is are my values acceptable? If not what would be causing the low compression on all cylinders equally?
Thanks in advance
PaulC5
x 682
Re: Citroen Berlingo 2016 Compression Values
Unread post by PaulC5 »
Possibly it is not turning over fast enough to give a good reading.
shtu
x 76
Unread post by shtu »
Look through my older posts and you'll find tables of multiple compression tests against a roughly 110k mile engine.
Of course, there is variance between test gauges, etc., so bear that in mind. Take out all the glowplugs when testing.
