The hook broke, and a replacement part for this piece of plastic is upwards up of 75£ according to dealer. Overprice for a small piece of plastic, so I was looking for making my own on TinkerCAD but it didn't turn out successful.
I can't reliably find it on 3D models catalogs either.
Does any one know where to find it for 3D printing ?
3D Print model, middle row windows, sunblinds hook ?
Solarriors
- x 7
Istvan 1953
Re: 3D Print model, middle row windows, sunblinds hook ?
I would recommend you locate a printer company to ask if they know of printing services or a person that would assist. I am currently three D printing the headlight washer outlet through a retail electronic sales that offer consumer printing service. This is New Zealand
talking.
Solarriors
- x 7
I have a 3D printer, I'm looking for the 3D asset.
Solarriors
- x 7
Sloppysod
- x 397
Can you measure the broken piece? I have Catia and can save as .ssl files (3d printer files). Send me the dimensions, we may be able to do something - I like to play.
I needed the Parking Sensor holders for my C5 and designed and had 5 printed, right first time too!
Stu
Solarriors
- x 7
The piece is a bit complex but the only thing that matters is the cylinder that gets into the hole. The rest is just any shape of handle basically freely artistic.
I can take more pictures for reference but in regards to the cylinder it's 3mm diameter and 70mm length.
However it needs to clip inside so I need to figure a way to change the length so I was thinking of putting two cylinders and carrying out a hole in one of them and protruding in the other that they will clip inside and lock when you twist. I had a CAD model
- x 1074
No you can't bump, is that the same as the C8s rear passenger window blockers?
Champion of Where's CitroJim
Sloppysod
- x 397
If you have a modelbi can convert it.
Stu
Solarriors
- x 7
By bump I meant bump the topic lolRp0thejester wrote: 06 Mar 2026, 19:03 No you can't bump, is that the same as the C8s rear passenger window blockers?
It looks like it is the same yeah
- x 1074
If you get any success then let us know!!
Solarriors
- x 7
Any success in what finding parts or making a 3d print model ?
Solarriors
- x 7
I have the TinkerCAD link, will update when it's approved.
